header gaskets...
i'm about to reattach my headers with studs instead of bolts and i don't want these things to ever leak again...
is straight rtv a good idea? or should i just use a gasket? both?
thanks in advance!
thanks in advance!
ORIGINAL: 7upedition
copper fel pro gaskets, locking header bolts and a touch of medium strength loctite on the bolts... you'll be all good!
^^^^ +1 and the loctite is overkill even, the locking header bolts will do it, after you go through a heat cycle or two, re tighten them all.
ORIGINAL: fordguy17
thanks in advance!
thanks in advance!
Fel-Pro 1250 exhaust gaskets. Header studs are a good idea. Make certain to use anit-sieze on the threads going into the heads.
Get locking nuts. Not the oval ones. The ones that are serrated on the mating surface.
I tried copper gaskets and they didn't work, you've got to tighten the ba-jesus out them to seal. These were on aluminum heads and I didn't want to strip the threads. I've had the 1250's and stage 8 locking bolts on the car since '98 with out any leaks or loose bolts, so far.
ok. i got some percys alumium gaskets (resuable) and am using studs.
so far it looks far more reliable than any paper gasket/bolt combo has ever looked on my car.
i'm gonna fire it in a few days to see what it does.
thanks everyone!
thanks everyone!
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
