tune up
im looking to do a tune up in my car. what parts do you guys recomend for the tune up. what size wires and what kind of plugs and other good parts for the tune up that i will need. does summit make a kit i can use to work with my 302.
On a tune up all you need is spark plugs, wires, and distributor cap. Maybe some O2 sensors.. I would stick with Motorcraft with the plugs (bosch's plugs are smaller then motorcraft) . The wires... i'd say either motorcraft, taylor or MSD... same with the cap... O2 sensors go with either motorcraft or bosch.
Also you could put some good oil in it..... Mobil 1 and a good filter K&N, Hastings...
Dont use fram,puralotor,stp..etc.
Change the coolant.
Change the air filter.
Clean the throttle body plate.
Run a fuel system cleaner through your next full tank.
Change the coolant.
ok thanks for the info. do you recomend motorcraft platinums. . i already have knn air filter so i should just clean it. i might need to get the fuel injectors proffesionally cleaned and im going to get a new fuel filter. any recomendations on the fuel filter brand.
is this what i need for my tune up. not exactly that but something like it. cost about 30.00 from summitt.
[IMG]local://upfiles/5264/453BF9BF5B094DDB85C2213921F1AEB7.jpg[/IMG]
I start here to get the suggestions listed from the other guys...
http://www.parts123.com/PartFrame.as...CCARVILLE_FORD
then type tune up in the search field... 5.0 SPECIAL! 87-95 5.0L Tune Up Kit $99.00
Keri
Keri
