Here's what I'm ordering tomorrow
Here's the list I'm ordering for tomorrow, you guys talked me into not going cheap (which is a good thing)
Trick Flow stage 1 cam
http://store.summitracing.com/partde...0&autoview=sku
Trick Flow valve spring upgrade kit for iron heads
Summit timing chain and gear set
Ford Racing full gasket set
This should take care of that oil leak
RE: Here's what I'm ordering tomorrow
prime you dont need a new x member for your 600, just grind the welds that hold the x membe in place slide it back install tranny and drive it for a few miles get back under it tighten the bolts down good and then reweld the x member,, did mine and worked fine, no problems here,,
