Its been a while...WHAT do you think?
RE: Its been a while...WHAT do you think?
We are relocating the electric water pump so i can run a bigger crank pulley, changing the injectors from 72lb to 96lb, crankin the boost up to around 25-28lbs, and poorin the coals to it. I ran out of fuel injector thats why it was limited to 679.
The tko is rated at 600, I am not powershifting though (time bomb). With a powerglide with a brake the car will run 9's now. I have a alum flywheel with a spec 3 clutch and it hasnt skipped a beat yet. With an auto it gets boring, i like having to shift, it get interesting.
You can have the 600 proshifted and it will take 900. The hardest part is getting a clutch that will hold. I do my burnouts in third gear and havent had any problems yet with slippage.
That is my goal. Right now the car spins the tires and pulles the front end off the ground about 8 inches. With the susp. upgrades and lightning the car I am hoping to drag the bumper.
I have tryed to scan the dyno and the 1/4 mile sheet but it is very blurry for some reason. I will have my buddy try and fix it. We are editing a video from the car on the dyno and some good 1/4 mile passes, when he gets it done I will post it here first.
