Street Heat or Track heat and what size injectors
Old 11-22-2006, 09:56 PM
89Ford
89Ford's Avatar
Default Street Heat or Track heat and what size injectors
Buddy's car has all forged internals a "race Preped" AOD trans with I think a 3000 Stall converter, the engine a trick flow twisted wedge heads and a TF stage 1 cam...what intake would be best for that setup Track or Street Heat? and what size injectors
89Ford is offline
Old 11-22-2006, 09:59 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: Street Heat or Track heat and what size injectors
need more info..he could still use the 19's with stock compression....or could go to a 24#
2 kwik is offline
Old 11-22-2006, 10:05 PM
89Ford
89Ford's Avatar
what info do you need
89Ford is offline
Old 11-22-2006, 10:06 PM
89Ford
89Ford's Avatar
i would really like to know if one intake is better for the automatic trans
89Ford is offline
Old 11-22-2006, 10:24 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
the trans is not in the equasion so to speak the intake needs to fit the engines rpm range....I would say the street heat will work good to help keep airspeed up
2 kwik is offline
Old 11-23-2006, 03:22 AM
89Ford
89Ford's Avatar
well what i was thinking since its an auto wouldnt it like shift it at like a lower RPM so you wouldn't really be taking advantage of the of the peak torque using the track heat....b.c i thought that the track heat doesnt make its power until alittle higher in the RPM when compared to the street heat
89Ford is offline
Old 11-23-2006, 03:29 AM
88BlueGT
88BlueGT's Avatar
I would also say go with the track heat. Also, you might be able to pull of 19's with that setup but I wouldnt want to... go with the 24's.
88BlueGT is offline
Old 11-23-2006, 03:39 AM
89Ford
89Ford's Avatar
its my buddy's car, but he insisted on going with 30# injectors he said thats what the guy told him he HAD to use, I just think its more than needed
89Ford is offline
Old 11-23-2006, 03:43 AM
88BlueGT
88BlueGT's Avatar
With a track heat and full bolt ons (exhaust, maf, tb, etc.) he will be close to 300rwhp. No need for 30lb injectors. Hes barely exceeding the limits of the stockers let along 24's.
88BlueGT is offline
Old 11-23-2006, 03:51 AM
89Ford
89Ford's Avatar
so what do you suppose he would run in the 1/4 if has the AOD with alittle suspension mods
89Ford is offline
Quick Reply: Street Heat or Track heat and what size injectors
