Megasquirt
#23
RE: Megasquirt
cool and when you say assemble do me plug the wires into it or do you mean actualy but the ecm together. ok future plan for my car is 750 WHP and i only want to replace to computer once so will this support that?
ORIGINAL: AdderMk2
the learning curve is actually quite the deciding factor in this one for me,,, MS is EASY to use... not to mention there is ALOT more support for it than tweecer will EVER have. The Megasquirt is a very simple, easy to use interface, where-as with the tweecer.. you need to learn the "jargon"...
MS is definitly better.. hands down.
I'll be assembling mine next weekend, i'll take some pics and maybe even a quick vid of a stimulator datalog
ORIGINAL: 94gtcoupe
ok adder now i'm curious... you always talked about the tweecer, so whats better IYO, don't take the learning curve into factor since i'm fairly decent at tunner software... what what system has more options, etc.
#25
RE: Megasquirt
ORIGINAL: AdderMk2
when i say "assembling" i mean it quite literally....
the KIT costs about $250
if you want one thats already built, they are around $450-500
#26
RE: Megasquirt
those pieces that you see there are the megasquirt itself... like i said.. its a stand alone engine management system. you completely disconnect your motor from the stock ECM and everything is then run to the megasquirt instead
#27
RE: Megasquirt
ORIGINAL: 94gtcoupe
http://diyautotune.com/cars/customer...urbo_truck.htm
http://diyautotune.com/racing/bonnev...edweek2006.htm
