4 lug disk brakes
Old Nov 24, 2006 | 03:36 PM
smbikes's Avatar
smbikes
Default 4 lug disk brakes
I have a set of Cobra R rims on my car so i want to keep the car a 4 lug but i want disk brakes on the rear. any on know how to make the rear disk brakes but keep it 4 lug?
Old Nov 24, 2006 | 05:45 PM
SPE926's Avatar
SPE926
Default RE: 4 lug disk brakes
SSBC.com sells a 4 lug rear kit but it is pricey. Also you can get the rear brakes off an 87-88 thunderbird turbocoupe. They came with 4 lug disks stock. Ford used these same brakes on the 93 Cobra. But if you use the Turbocoupe brakes make sure you pull all the hardware including the axles as they are a little longer than the foxes or you could use the whole rearend from the turbocoupe. They are 8.8's and had either 3.55's (stick) or 3.73's (auto) stock but you will have to move the quad shock mount down 2 inches.
Old Nov 24, 2006 | 07:34 PM
7upedition's Avatar
7upedition
i had a lot fo good responses and links in a thread i posted a few weeks back, do a search for 4 lug disc brakes or 4 lug rear disc.... you'll see
Old Nov 24, 2006 | 08:52 PM
Valcore's Avatar
Valcore
wilwood makes some. They are expensive but bad ****!
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
