no feel
i never figured installing a firewall adjuster would be a big ordeal... the adjuster itself is 2 pieces... leave them together
insert the threaded end into the firewall
there should be a locationg screw to help you line it up properly
remember to remove the black rubber piece from the end of the clutch cable.
the 4 small tabs on the white plastic piece which is UNDER the black rubber piece will need to be cut down
Can you take spme pics of what you're trying to do? I think you're missing something in the process.
Maybe this will help you
https://mustangforums.com/m_1331822/tm.htm
its like 35° outside right now... so you better appreciate this pictures
[IMG]local://upfiles/26017/44218ECF471C4757B21FAC8615CB30B6.jpg[/IMG]
[IMG]local://upfiles/26017/4996940BE6664FB9BA85E26047627CF2.jpg[/IMG]
