Ok, here's what you can do at home. Get a pice of vacuum line. Connect it to the vacuum tree on the firewall. Hook the other end directly to the egr vale. If the valve and the passages are good, the car will either run rough or stall. basically opening the egr valve at isle creates a big vacuum leak. If it doesn't, the valve and or the passages are clogged.
ok, ill check into that... i assume i can get a piece of that tube from like autozone or some **** right? gotta go there for some oil and o2s soon any way.
