flashers work...blinkers dont...any suggestions ?
RE: flashers work...blinkers dont...any suggestions ?
ur looking for a trans? check out www.astroperformance.com they have good stuff... but if its just gonna be a backup spare, hit up a junkyard
well a pos from a junkyard is better than nothing if his goes to shyt. i suggest checking out that site, but yea, id get a junkyard one as my "just incase, and just to get me by"... hell, it could easily be that a car was in a front end accident... and they totaled it... trans might be fine... u never no. it could also be ****, again, u never no, but itd be cheap and better than nothing
It could also be a bad Turn Signal Flasher. The hazzards use 1 flasher and the turn signals use another. I just had to replace mine. Was only $10. Its worth a try.
yea theres a flasher underneath the dash basically on the steering column. first i would suggest flicking the switch on and off several times and making sure all the connections in the wires and on the flasher are tight. i had no signals for a while and i connected everything tight and they worked again. can you manually make them flash? instead of havin them click and hold and flash themselves try and flick the lever and see if it works that way. if it does you have a bad flasher or at least a connection to the flasher
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
