Cheapest worthwhile foxbody?
Old Nov 28, 2006 | 06:54 PM
Jmag034's Avatar
Jmag034
Default Cheapest worthwhile foxbody?
Im looking for a cheapo foxbody in my area to make into my racing car, my sn95 is too mint to modify (also its an AOD vert)
how much would your average foxbody with 130k+ miles on it, in decent condition, interior can be ****ty, few dents is fine, but about how much do they usually go for?
Black Snake's Avatar
Black Snake
Default RE: Cheapest worthwhile foxbody?
4k
Old Nov 28, 2006 | 06:56 PM
P Zero's Avatar
P Zero
Ive seen as low as $500, for a rough body but running 5.0 to as much as $10k +, its all in the luck of the draw.
-P.
PS: 79-82 models are the lightest.
jrstall's Avatar
jrstall
there is a white 84 i believe it is foxbody for sale in my area and they are asking 3k (only because i know the dealer)
Old Nov 28, 2006 | 06:57 PM
jaznasy69's Avatar
jaznasy69
i bought my last one 5 weeks ago for $350 just needed a drive shaft
Old Nov 28, 2006 | 06:58 PM
frdmstng1986GT's Avatar
frdmstng1986GT
i picked up my 86 gt 5 spd with 56,000 miles on it for $2500.just got to look for the deals. buy a 4cy notch and then put a 351 carb in it with a posi 8.8 out of a 5.0 stang and an built aod.
Old Nov 28, 2006 | 07:00 PM
P Zero's Avatar
P Zero
ORIGINAL: frdmstng1986GT
IF youre going all out drag mighta s well get a C-4, theyre cheaper to build than AOD's. The c-4 has only one set of planetaries where as the AOD has 2.
-P.
Old Nov 28, 2006 | 07:04 PM
86onboost's Avatar
86onboost
i got my 86 notch, witha 92 engine and a c-4 tranny, with 2 carbs, torque converter, some extra pipes, and an extra 302 block, for only 600, all it needs it electrical parts such as alternator, and coil, and ignition box, and it will be up and running
Old Nov 28, 2006 | 08:49 PM
drewguere's Avatar
drewguere
Where are you located
Ill sell you mine if your close enough...its not stock either
Old Nov 28, 2006 | 08:52 PM
95walter's Avatar
95walter
what do you have and where are you
ORIGINAL: drewguere
