universal joints????
when i drive my car it does fine until about 60 65 and a little vibration comes in and you can here clunking noises aroung the back of the tranny and it also clunks a little when the car gets in a situation where you have to give it more gas like if i was going up my driveway in first the car is a 90 gt with a t5 any ideas will be great
RE: universal joints????
That sounds like a u-joint to me. You can also tell when your driving in a lower gear. You can hear a clunk when you hit or let off the gas. To tell for sure though you have to get under the car and check for play in the u-joints.
I had a bad vibration when i was accelerating under 1000-2000 rpms. Go under your car and put your hand on the drive shaft and your other hand on the yoke. Move it like your giving someone a "indian burn" like move them both in oppisite directions and if's there play. Replace.
Mine was bad and fixed it and was perfect. Very easy to do. Mark the driveshaft and the yoke because they are balenced from factory then, drop the drivestaft take a socket and a hammer. Knock that baby out then just replace man. Should fix your problem. Unless of course it's just your tires need balenced.
I know exactly how to explain it, if it makes the predator noise when you put a load on it, its your U-Joints. Just lift the car up and see if the driveshaft has any play in it. Btw by the predator noise, I mean from the movies, the sound the predator makes, its exactly how it sounds, lol.
well i changed them and the vibration is still there but the funny thing is is when it starts if i give the car some gas it stops but when i completly let off it does it the worst so i don't know what it is now
ORIGINAL: stangpower96
ORIGINAL: roundman
Now that sounds like excessive backlash in the ring and pinion gears to me. Suggest you get them looked at and maybe replaced if they're worn that badly.
