T5 bearing retainer question
Ok..I need a bearing retainer for my t5 but not sure what kind I need...The numbers on it are 13-52-027-919..and someone told me the ones ending in 919 are v8's..I tried one from a 88 t5 but didnt work...Mine is a 84, People told me a 88 would fit an 84, but in this case it didnt..so is this true? what kind of retainer do i need?
RE: T5 bearing retainer question
Remember to look at the tag attached to the tail stock bolt (4 total). That tag will have the correct number not the number molded into the side of the shifter housing area.
Get the correct number and go here to Identify you application: http://www.5speeds.com/t5/index.html
Good luck,
Roger
Good luck,
Roger
+1 steel makes the clutch release so much more consistant
ORIGINAL: silver91gt
get a steel bearing retainer, the aluminum ones get chewed up easy.
ford makes one
ford makes one
why non internet? D&D performance sells them and makes great parts, http://ddperformance.com/ you can also order over the phone, i'm sure summit and jegs sells them too
