AOD Trans
Old Nov 29, 2006 | 01:19 PM
Pacerfan's Avatar
Pacerfan
Default AOD Trans
I have a 92 GT with a AOD trans and would like to know if a non-aod c-4 trans (or any non-aod) will work...Thanks
Old Nov 29, 2006 | 01:34 PM
BlackLX's Avatar
BlackLX
Default RE: AOD Trans
ORIGINAL: Pacerfan
Will work with what? Are you just wanting to know if you can take out the aod and swap in a c4?
Old Nov 29, 2006 | 01:35 PM
88BlueGT's Avatar
88BlueGT
Yes, you can swap in a C4 but there are a few things that you will need to change.
Old Nov 29, 2006 | 04:09 PM
Pacerfan's Avatar
Pacerfan
Thanks for the replys... I just needed to know it it was worth getting the AOD rebuilt for around $1500 vs a rebuilt C4 for $500
Old Nov 29, 2006 | 04:10 PM
88BlueGT's Avatar
88BlueGT
Depends on how much you like your OD
88blackgt's Avatar
88blackgt
it depends on what you use the car for, the c4 doesnt have an overdrive
Old Nov 29, 2006 | 04:19 PM
Pacerfan's Avatar
Pacerfan
I'm just going to use it for a weekend cruiser...I've past the "need for speed" days
88BlueGT's Avatar
88BlueGT
Well are you concerned about gas mileage, highway use, etc.? A C4 with 3.73-4.10's, etc. will be like 3,500+ on the highway at like 70
Old Nov 29, 2006 | 04:22 PM
88blackgt's Avatar
88blackgt
sounds like an aod would be your best bet if its a cruiser
Old Nov 29, 2006 | 04:28 PM
BlackLX's Avatar
BlackLX
Since you said weekend cruiser you'll just drive it around town right? If so, go with the c4. You only need OD for highway speeds.
