tremec t5 need advice
it pops out of first when its cold and second just grinds. i know the front tranny seal is definitly leaking a little when its on a hill. so my question is do i have to have it rebuilt, or would it do that if the fluid was low. thanks
RE: tremec t5 need advice
ORIGINAL: dimebag
you could check the fluid, but im willing to bet its your 1/2 syncro
syncro shouldn't cause it to "pop" out of gear unless it's realy realy bad, yes low fluid will cause it to grind (depending on how low the fluid is) my guess is on a realy bad syncro tho
rebuilding it is replacing the syncro's, usualy that the only thing you replace other than bearing/bearing retainers
ORIGINAL: pizzarolls
well i decided taht if i have to do synchros...i might as well have my buddy rebuild it....its winter here anyway.[:@]
true that but all transmissoins that where made before they where bought out are still considered Borg Worner transmissions, after all that is the name stamped on the case of it
ORIGINAL: gspfunk
Clutch may need adjusting. If it's not going into gear all the way it can do that, too.
BTW, Tremec bought out Borg-Warner transmissions, so they are the same thing.
