Should I increase to 24LB injectors?
I have Edelbrock Perfomer II intake, 65mm TB, 255IHP fuel pump, 3:73 gears, Shorty headers, and flowmaster exhaust. I was thinking of getting a bigger mass air sensor, when I started thinking should I get bigger injectors. I plan I putting in a new cam and Edelbrock performer heads after this winter. I've got my timing set to 14 degrees if that makes any difference. Should I put in the 24 pounders?
RE: Should I increase to 24LB injectors?
I would wait, there are other mods that you will gain alot more from at this point. There is a injector size calculator in the tech articles for when you need some
TfcCDR
09-14-2015 12:08 PM
