Getting Ready to make a big order
ok heres what i have
electric fan, underdrive pullys, smog delete, CAI, LT headers, Prochamber midpipe
Now here is what im ordering
Trick flow trck heat upper and lower, 65mm TB, 76mm C&L mass air, 155lph fuel pump, #24 injectors, 3:73 gears, 1.7 RR, Custom chip& dyno tune.
Do you have any sugestions. i want to finalize everything thanks
RE: Getting Ready to make a big order
yea get a accufab 70mm Tb and EGR plate rather than the 65mm... unless the intake has a 65mm inlet, but i'm almost certain its 70mm or 75mm... and you need heads
don't need 24lb injectors unless you plan on spraying it soon..
also a 70mmtb is pretty big for a stock engine...but like i said, if you plan on upgrading soon it is better to buy only once..
24 lb injectors are overkill on a stock engine. If you decide to go with them remember to get your MAF calibrated to the 24 lb injectors and to set your fuel pressure according.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
