Stumbling cold start advice...
I have a '93 GT Conv with 36k miles and 5spd. Previous owner placed a BBK induction, MAF, headers, and an offroad exhaust and flows. After EVERY start the car idles rough, hesitates, and stumbles for about three miles, then clears up everytime and runs normal. Any advice that would fix this?
RE: Stumbling cold start advice...
Let the car warm up before you start driving it? The computer is probably on closed loop (or is it open? I always get them confused) That means it changes the fuel and timing curve to help the car get warmed up.
ORIGINAL: musclemustang94
If it is doing it EVERY start up then you might have a bad Engine coolant temperature sensor.
Im going with the ECT. It effects the air/fuel, spark timing, and idle rpm at startup. The computer switches to a fixed warm signal when they go bad so when the engine does warm up it runs properly but during a cold start itll give you grief. Needless to say that once everything warms up the engine will run fine. A low coolant level will cause a false rich rich signal leading to a warm stumble.
It never hurts to check you TPS. It should read betwwen .98-.99v key on engine off. youll need a voltmeter and 2 pins. I believe its a green and black wire? At last check mine read a pathetic .58 but never had any troubles with a cold start.
As for the MAF, im not sure. I had one go bad causing a stall but was only during reverse and it didnt matter what the temp was.
Your o2 sensors should be replaced every 30k miles so if you havent already, replace them. Clear the computer when youre done.
