afr or trick flow
RE: afr or trick flow
I dont think i understand, so if you get afr heads you will go with another stock block and stock cam? Or if you go with TF heads you will be using your exiting block w/ aftermarket cam? In that case i vote TF but i am probably not getting it
since i just posted in your last thread about the email you got from trickflow did you email them back and ask what cam they would recomend to use with your factory 86 short block? i would do that first.. i'm not sure you will be able to run a"big" cam due to the piston to valve clearence issue.
nmeril, what i wanted to do was
1) got afr with a 89 block and a decent size cam
or
2) now that i kno trick flow can fit go with trick flow twisted wedge heads, and that same decent size cam with track heat intake
or
