spark plug question
Old Aug 31, 2004 | 02:04 PM
quantum555's Avatar
quantum555
Default spark plug question
what spark plugs can be used in a 91 5.0 mustang. only mods are 9mm wires, blaster coil. i have heard you are supposed to use a certain temperature plug... is there a certain gap or brand that works the best??? any help would be appreciated
j
Old Aug 31, 2004 | 02:21 PM
Duffs302's Avatar
Duffs302
Default RE: spark plug question
I haven't heard that, but I use Motorcraft plug.
Old Aug 31, 2004 | 02:57 PM
stangcrazy's Avatar
stangcrazy
I just use Bosch Platinum+4 plugs no need for changing gaps.
http://www.boschusa.com/AutoParts/Sp...PlatinumPlus4/
Old Aug 31, 2004 | 05:17 PM
luckythirteen13's Avatar
luckythirteen13
i use platnum autolites. i used the bosche plugs (platnum 4's) in another car and found them to be worthless. they fell apart on me really quickly.
Old Aug 31, 2004 | 09:38 PM
bobby's Avatar
bobby
the only plug that really burns hot enough for fords is motorcraft and autolite. the platinum 4s are NO better then the regular platinum, there a joke! just run motorcraft or autolite, u cant get a better plug for our cars! or some denso iridiums if u wanna pay $70 for a set of plugs.
Old Sep 1, 2004 | 10:53 AM
quantum555's Avatar
quantum555
thanks guys!!!
Old Sep 1, 2004 | 01:31 PM
vfast's Avatar
vfast
I ♥ Acer
autolite 24 I believe in a stock engine
Old Sep 1, 2004 | 02:50 PM
roundman's Avatar
roundman
use the motorcraft or autolite stock spec'd plug gapped at .052" and you should be fine!
BTW, all plugs have a heat range rating that has to do with the length of the ceramic insulator portion of the plug that sticks down into the cylinder. the longer this insulator, the hotter the plug rating and the shorter it is, the colder the rating. as engines are modified from stock, you may have to change the heat range rating of the plug to keep them burning clean, i.e. switch to a hotter plug OR to keep them from burning up, i.e. switch to a colder plug.
Old Sep 1, 2004 | 02:54 PM
EmptyEvergreen's Avatar
EmptyEvergreen
denso iridiums here...i dont mind spending over one hundred on a set of plugs
Old Sep 1, 2004 | 04:16 PM
roundman's Avatar
roundman
ORIGINAL: EmptyEvergreen
Hey vfast, check this out! And you accuse me of being rich? hahahaha
