Anyone ever re-use the headbolts???
#24
RE: Anyone ever re-use the headbolts???
I would replace them, I reused mine one time and blew the head gasket shortly after, would have been much cheaper and easier if I would have just went ahead and bought them. Too much work to have to do it twice, just my two cents
#25
Replace the bolts, they are torque to yeald and you will not get proper torque. You will have to do it again after you blow a gasket, so do it right the first time. Not a bad idea to run a tap into the block either to clean out the treads, specialy the short ones in the water ports.
