347
Old Dec 4, 2006 | 02:45 PM
drewguere's Avatar
drewguere
Default 347
I have a 302 that is bored .60 over. I would like to stoke it as well. What is involved with that?
Do I just need a new crankshaft, and new connecting rods? Because my pistons already are set up for the .60 over bore.
This just seems way too easy and I feel like Im probably forgetting about a BUNCH of things...
Can someone explain this whole thing to me...
Old Dec 4, 2006 | 02:50 PM
Bwebb Stang's Avatar
Bwebb Stang
Default RE: 347
you need to get on jegs or summit racing and look up one of their rotating assemblies.
Old Dec 4, 2006 | 04:26 PM
Jared_blown5.0's Avatar
Jared_blown5.0
Default RE: 347
a 347 is:
4.030" bore with a 3.4" stroke
Old Dec 4, 2006 | 04:32 PM
Jared_blown5.0
Default RE: 347
you would have a 352 with you 4.060 pistons
Old Dec 4, 2006 | 05:38 PM
SteveSkal's Avatar
SteveSkal
Default RE: 347
If your gonna make big power with that don't be surprised if you ventilate that block!
Old Dec 4, 2006 | 07:06 PM
dillon1340's Avatar
dillon1340
Default RE: 347
think you have to have the bottom end machined for clearance since you would have more stroke. the journals need to clear the block.
Old Dec 4, 2006 | 10:51 PM
tinman's Avatar
tinman
Default RE: 347
I think it's doable but how much strip time to how much street time are you planning to do?
If it's a strip only car you can pour the block full of cement and not really worry it...
Get block 'sonic tested' at a good machine shop before you make big plans. If block has walls of about .120-.140 you will be okay with cement, MAYBE........
Old Dec 4, 2006 | 11:17 PM
mattdel's Avatar
mattdel
Default RE: 347
cement? am i the only one that has never heard of this? i realize that track only cars wouldn't require cooling systems, but fill with cement? that'd be heavy as ****
Old Dec 4, 2006 | 11:26 PM
VigCS's Avatar
VigCS
Default RE: 347
.060" over? Those poor, poor cylinder walls.
Old Dec 4, 2006 | 11:34 PM
stocksuspension's Avatar
stocksuspension
Default RE: 347
u need a whole piston designed for a 3.4 stroke.. i u use the .060 pistons u have now u will be about 1/2 inch positive deck!!!!
