manifold enough space?
Old Dec 4, 2006 | 05:58 PM
stangman94's Avatar
stangman94
Default manifold enough space?
Im sure this question has been answered before but i couldnt find it using search. I plan on getting a trickflow street intake manifold. I forgot where but i heard it doesnt fit under the stock hood of a 94-95 model because of the spacer you need. Is this true? or will it fit just fine under my hood
Old Dec 4, 2006 | 05:59 PM
philthy89fifty's Avatar
philthy89fifty
Default RE: manifold enough space?
if you use a 3/8" spacer it will. a 1" spacer is a no go. you don't need the spacer in either case.
Old Dec 4, 2006 | 06:22 PM
ryan_89_mustang's Avatar
ryan_89_mustang
What is the benefit to the spacer? Just curious.
Old Dec 4, 2006 | 06:23 PM
nmerrill's Avatar
nmerrill
i think it is supposed to make the runners longer making more tq.
Old Dec 4, 2006 | 08:24 PM
philthy89fifty
^Thats not really what gives the most benifit. Its the phenolic material that does not allow the heat from the block to transfer as readily to the upper intake thus heating the incoming air. not much gain at all but worth the 30-40 bucks just to have one more mod on your list.
Old Dec 4, 2006 | 11:30 PM
88canadianstang's Avatar
88canadianstang
I agree with philthy89fifty....classic screen name anyway I have a GT40 with a 1" spacer and the extra space this creates means a litle more air will enter the engine. And yes the spacer does a great job in lessening the heat transer to the upper manifold. Every little bit adds up.[sm=gears.gif]
Old Dec 5, 2006 | 06:38 AM
Evil_F's Avatar
Evil_F
Part of why a spacer works is because there is more volume in the intake. And when the motor goes to suck it in. There is more air in the larger volume intake to suck in. Sort of a trick. But I think the spacer is also for when you have tall valve covers. So that intake will clear the valve covers.
Old Dec 5, 2006 | 07:49 AM
Black Snake's Avatar
Black Snake
I used one mostly for space cause these damn taller valve covers. But it helps with heat transfer for sure, I can run my car all day and I can touch my intake with my hand without singing it. Never could with my old intake
Old Dec 5, 2006 | 09:41 AM
7upedition's Avatar
7upedition
Nice, intake spacer is for valve cover clearance, intake air volume and temperature. Didn't know about the temp [&:], yahtzee![8D]
mrtrodonet
Sep 19, 2020 03:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
mustangheaven
Sep 29, 2015 11:00 AM
