Electric Waterpump
Old Aug 31, 2004 | 10:42 PM
Obsol3te's Avatar
Obsol3te
Default Electric Waterpump
Looking into buying an electric water pump.
Just wanted to hear from the people who have one, about which one would be good for STREET use.
I'm lookin for a NON pulley system, so then I'll be down to THREE
Also, if none of you can help with that. What do the stock pumps do for GPH wise?
Because I can just go by that if none of you know about the electric pumps.
Oh and if ya can't finger it out its for the car in my sig.
Thunk u
Old Sep 1, 2004 | 05:08 AM
FoxGT's Avatar
FoxGT
Default RE: Electric Waterpump
My friend had an electric fuel pump & claimed the engine ran hot. Not sure if he installed it wrong or if it just sucked. I like the sign avatar. [sm=smiley36.gif] If you get one let me know how it works.
Old Sep 1, 2004 | 01:43 PM
vfast's Avatar
vfast
I ♥ Acer
I would not recommend one for the street as it cannot pump fast enough at higher speeds..just buy a hi volume water pump and use a hi-po stat which has a bigger ofice for h20 to flow better use a water wetter additive from redline
Old Sep 1, 2004 | 02:29 PM
roundman's Avatar
roundman
ORIGINAL: Obsol3te
Thunk u
OH THIS IS GOOD!
besides the Moroso add on electric motor to drive a stock water pump, what other ELECTRIC water pumps you ever see with a pulley on them? hahahahaha
and most of us aren't that stupid that we don't know it's for the car in the sig either!
THUNK YOU TOO! I needed a good chuckle this morning!
Old Sep 1, 2004 | 03:23 PM
Italianstealth's Avatar
Italianstealth
Not a good application for street use. If it craps out or loses power for some reason or another you will not know it before it is too late!
Also, why do you want an electric one anyway the draw from a pulley system is minimal at best I could not imagine you picking up any noticiable HP from this
Old Sep 1, 2004 | 03:43 PM
roundman's Avatar
roundman
ORIGINAL: Italianstealth
there ain't no such thing as a free lunch! at higher engine speeds, the water pump alone can take 15 HP from the crank and away from the rear wheels, more if it has a manual fan attached. and OB is our most vocal member about getting more HP to his rear wheels so he can keep up with me! hahaha
Old Sep 1, 2004 | 04:28 PM
Italianstealth
[quote]ORIGINAL: Obsol3te
free lunch, that was good.
I realize that there is a solid amount of drag therefore resulting in HP loss but on a street application I could not imagine it being that significant, was my main point. Not getting into a pissing contest with you just explaining my reply. Trust me when I say most of the ppl on this board know more about 5.0's than I do this is my 3rd one but my last on was back in 94. (back then I knew plenty but times change and knowledge gets lost) I will ask you this though. Are all the Convertibles this friggen slow? all of my other ones were coupes and much much faster.
Old Sep 1, 2004 | 04:37 PM
roundman's Avatar
roundman
the convertibles weight about 200 lbs more than a coupe and this slows them down unfortunately. there is extra steel bracing in the chassis due to the lack of a roof on the verts that adds this extra weight. you can make up the difference with some basic bolt on mods like underdrive pulleys, new chip on ECU, headers and exhaust, etc.etc.
Old Sep 1, 2004 | 08:57 PM
tinman's Avatar
tinman
Agree with the Roundman on this one. I've been using the belt drive type pumps for at least 25 years on differant cars. Pretty consistently good for about .15 off the ET's. I would think that the 'self contained' types, Moroso, Meziere, etc wouldn't do any better and they $330-$400.
On the streets, never will work unless you never drive over 40 MPH for more than about 2 miles.
Wetter Water is a good product, I've been using it for about 10 years in everything I own, here in Arizona you need all the help you can get. Just remember the Wetter is only good for about 2 years and it IS NOT anti-freeze.
Old Sep 2, 2004 | 12:28 AM
Obsol3te's Avatar
Obsol3te
Free power is free power
Even the 37 GPM one isnt that good for street use?
LiquidDrink
Sep 29, 2015 10:06 AM
mrappe
Sep 26, 2015 10:16 AM
allenmaty
Sep 24, 2015 09:17 AM
uberstang1
Sep 20, 2015 06:42 PM
TfcCDR
Sep 14, 2015 12:08 PM
