mods list for winter
Old Dec 6, 2006 | 02:13 AM
ford91mustang's Avatar
ford91mustang
Default mods list for winter
here is the list i am planning on getting over the winter...if you have any suggestions then let meknow before i start buying all of this.
1. march ud pullies
2. a/c delete
3. frpp c springs
4. transgo shift kit
5. shocks/struts (what company and what type should i get
6. rear control arms (i dno if i should get upper rears or not)
7. frpp ignition wires, cap and rotor, and coil
if there is anything else that i should get let me know, but i do not have a lot of $$$ so i cannot go too hardcore
Old Dec 6, 2006 | 02:14 AM
Glasersil's Avatar
Glasersil
Default RE: mods list for winter
I'm getting an S-Trim Next Month
Old Dec 6, 2006 | 02:18 AM
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
lakewood struts- 90/10's up front work well with 50/50's in the rear
Old Dec 6, 2006 | 11:22 AM
PJB's Avatar
PJB
3G 130 amp alternator if you plan on using the underdrive pulley on the alternator. Youll need it.
Old Dec 6, 2006 | 11:23 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Wheels and tires, maybe some suspension. That's about it I think.
Old Dec 6, 2006 | 11:46 AM
ROTTITANK's Avatar
ROTTITANK
stall converter would go good with the 4.10s
Old Dec 6, 2006 | 12:13 PM
7upedition's Avatar
7upedition
both upper/lower control arms, torque box plates, wouldn't bother with UD pullies, 9mm wires, motorcraft plugs, MSD rotor and coil, consider a manual valve body rather than a shift kit (lentech), what are your intentions with the car? that'll determine the shocks/struts/springs, either way best of luck to ya
Old Dec 7, 2006 | 02:10 AM
ford91mustang
my car is only driven in the summer and i occasionally will go to the strip, but i would want my car to have better performance then better handling...would the list i have make a difference in my 0-60 times at all???
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
mdg
Oct 1, 2015 07:04 AM
TimeLord101
Oct 1, 2015 06:40 AM
popsotto
Sep 28, 2015 06:58 AM
