cooling problems
ok for the last week or so i've been having coolant problems... some how my radiator is dumping out coolant into my reservoir and the coolant wont go back into the radiator... basically i have to fill the radiator with about 5 inches of coolant every few days. any ideas? keep in mind i have a new FRPP radiator, new 180 t stats, new water pump and mercury sable efan setup.
hmm i was thinking that too idk what the cap pressure should be for the FRPP radiator. i do know that my cap says 13 lbs on it. doesn't anyone know that pressure it should be rated at?
is the reservior full when you top it off?.....cause if it is by you adding more too it the reservior will have to lose it on the ground,and the 13lb cap saying it works or not just beens it's going to take less time to build pressure vs your stat opening
Galactic
Apr 29, 2019 02:56 PM
