PROBLEM WITH ALTERNATER
Old Dec 9, 2006 | 07:25 PM
great 8's Avatar
great 8
Default PROBLEM WITH ALTERNATER
Ok I just put a new alternater on my 86 5.0 and a new battery as well. My alternater won't charge my battery for sum reason. I kno for a fact that its the alternater cuz i just checked to see if the battery was getting a charge from the alternater and there is no charge at all. The alternater is BRAND NEW . Wat could this be and wat should i check ?
Aite thanxz
Old Dec 9, 2006 | 07:28 PM
mattdel's Avatar
mattdel
Default RE: PROBLEM WITH ALTERNATER
what is your voltage gauge reading?
Old Dec 9, 2006 | 07:35 PM
tmajikman's Avatar
tmajikman
might be the voltage regulator.
Old Dec 9, 2006 | 07:37 PM
great 8's Avatar
great 8
12.8 wen car is off and 12.4 wen car is runing
Old Dec 9, 2006 | 07:40 PM
great 8's Avatar
great 8
Are u talkin about the voltage regualtor thats mounted on the ALT or is there another 1 dats external that I should look for if there is an external 1 where should I look?
Old Dec 9, 2006 | 07:41 PM
mattdel's Avatar
mattdel
sounds like either a bad battery ground or defective alt.
Old Dec 9, 2006 | 07:48 PM
tmajikman's Avatar
tmajikman
I think there is an external regulator, I just don't remember where it is located, someone help us out.
Old Dec 9, 2006 | 07:55 PM
tmajikman's Avatar
tmajikman
+1 on what mattdel said about your grounds as well, make sure they are clean and tight, check the battery also with a load tester, at advance or autozone.
Old Dec 9, 2006 | 07:59 PM
settled4automatic's Avatar
settled4automatic
if there's an external voltage regulator, just follow the wires from the alternator to find it.
Old Dec 9, 2006 | 08:52 PM
great 8's Avatar
great 8
So The Alt could be defective even if its brand new i just got the ALT today. Also wat grounds should i check the battery ground and wat other grounds??
