Would this engine work well ?
Putting new ideas together on building a new engine for my 88 GT
Heres what Im Thinking:
Stock Block
Stock Crank fully balanced
Stock Rods fully balanced
Stock Forged 9.0.1 Pistons
Sealed Power Forced induction rings
AHR Winsor 5.0 heads w/165cc intake ports & 1.94/1.60 Valves
E303 cam w/1.7 roller rockers
GT40 lower intake & Cartech Sheet-metal upper
75mm TB
76mm Blow-Thru MAF
Garret T76 Turbo
1 5/8" Custom shorty headers into one 3.5" T4 Collector
4" Downpipe w/Dyno max Race Muffler & Turndown
42lb Injectors
Mallory 155gph Fuel Pump
Mallory Rails
How much power could this motor make at 12-15 psi ?
Stock Block
75mm TB
76mm Blow-Thru MAF
Garret T76 Turbo
42lb Injectors
Mallory Rails
RE: Would this engine work well ?
it sounds good but just be careful not to blow the block because with that turbo u could see well into the 400 hp range, maybe u should go with a stronger block or 351 or something
HIS S-197
08-10-2015 05:47 PM
