Boss 302?
Boss 302?
i heard where ford corp. made the boss 302 with 351 heads and i was wondering if i could bolt up a 87' 302 block and 87' 351 heads, just wanting to know if the bolt patterns would bolt up, anyone know for sure, and also i would like to bore the block to be a 347 stroker would this set up be a problem? i'm not doing this right now just making plans.
RE: Boss 302?
first off the boss 302 used cleveland heads and those will not fit ur block if u wanna go with the 351 w the gain is mininmal and not worth teh moeny to put them on
but if you are bent on putting them on they should just bolt up with the exception of heads bolts u might need newr ones and anythin else i may be missing someone please chime in
RE: Boss 302?
ORIGINAL: tinman
You need special pistons for them to work right, expensive........
RE: Boss 302?
and a different water passage u will need boss 302 pisons or a set of cleveland pistons pending upon which head u use 2 or 4v head and then with some more drilling to make for new head bolts and filling the old ones it just aint worht it
RE: Boss 302?
alright what about just the 347 stroker is that worth while like i said this is not happening now just plans but i'd like to put twin turbos or super charger on it too but i am not for sure street quality i want to be able the run the street without overheating every time i turn around, does any one know the running temp. for twin turbos?
