Dash Lights
Dash Lights
I have a 1991 Mustang GT 5.0 ... Tonight I was driving home when I noticed that my gauges weren't lit up. I turned off the car and turned it on, my air bag light came on, along with my seat belt light and emer. brake light. My gauges still worked properly, they just weren't lit up. Could this be a fuse blown out? or did my bulb burn out? If someone could please help me out I would deeply appreciate it. Thanks a lot ahead of time.
RE: Dash Lights
ORIGINAL: 91hatchgt
RE: Dash Lights
No they did not stay on, I just meant that they were working properly. How hard is it to change the bulbs? Where do I start? Do I have to pull the dash apart or what? I am definately going to check the fuses.. just odd that they went out all of a suden...
RE: Dash Lights
well if you have a haynes manual than just look up how to get the gauge cluster out than once you get that out than the bulbs are right in the back of the cluster which is a very simple job should only take about 30 min.
RE: Dash Lights
ORIGINAL: stangpower96
91hatchgt, you will need a philips head screwdriver, a torx head screwdriver, two small flat bladed screwdrivers, either a right angle philips head screwdriver or a 1/4" ratchet with a short philips head driver inserted into a 1/4" 6 point socket, and some patience to get the cluster out. they are numerous bulbs in the back and the chances of all of them failing at the same time is pretty remote, so I would check for the fuse first.
RE: Dash Lights
Yes, I have now noticed that even the AC component lights are out, so I am PRETTY POSITIVE that it is just a fuse, I will replace it tomorrow, but I am also writing down the instructions on taking out the pod JIK i need to do it someday... Thanks for all of your help and time though you guys....
RE: Dash Lights
actually i HAVE pulled the guage cluster out of a mustang im sorry if you are so slow that it takes you and hour just to get in your car look you need to watch the flaming and just shut up with the "you have never done it before" bs people like you really need the hell beat out of them and no im not mad just giving you my opinon just like you did me and roundman if you have a problem just send me a little pm and we will talk about it now have a nice day
RE: Dash Lights
Sorry about that! From the way you told him what to do, it sure as heck sounded like you hadn't done it before yourself and I was just trying to make him aware it isn't that simple is all. It's hard to tell sometimes when somebody knows what he's saying because he has done it and when they are giving an unsupported with experience opinion about what to do. I'll try not to do this to you again!
