DSS VS. R302 Vs. Dart Black
RE: DSS VS. R302 Vs. Dart Black
actuallly the car made 1500+ horse on an R block
http://turbochargedpower.com/1989%20Mustang%20LX.htm
ORIGINAL: primetime5.0
all a main support system does is hold the internals together once the motor splits
only problem with your logic bud, is the stud girdle strengthens the block where its not the weakest.
all girdles do is keep everything in a nice pile when the stock block splits in two down the middle of the lifter valley.
they are useless on production blocks since other areas of the block will fail before the crank area does.
there is more to the strength of a Dart block than just the 4 bolt mains. the entire block is stronger and beafier
ORIGINAL: redmustang83596
yes it will make it stronger than a block with factory 4 bolt mains
tieing all the 2 bolt mains together will not make it stronger than a block with 4 bolt mains...
right a stock style D.S.S will only handle 550 like i said. What I am saying is that if you have the same block one with 2 bolt mains and a main support system and the other with 4 bolt mains, the main support system will prove stronger than the same block with a 4 bolt main, if that makes sense.
Here you go bud
one turbo charged production 302
http://videos.streetfire.net/video/8...0a0177e6d0.htm
see where that block failed at the end pics?
THATS where they are weak
