Need Help.
Need Help.
I put a new short belt on to bypass the ac/smog and I also replaced a vacuum hose and now the engine surges up and down at idle... I sure it's not the short belt but the vacuum hose. Does this sound like a symptom of vacuum leak?
RE: Need Help.
Vacuum hose hooked to the emissions sensor in the left side:
http://i101.photobucket.com/albums/m...DSC02228-1.jpg
RE: Need Help.
it could be because the smog pump isnt turning, i havnt heard of a case where you felt it, but in theory, instead of air pumped through the line, exhaust would push into it, then fill up and clog, and release, so a constant change in back pressure would cause the idle thing
