Modding Plans For The New Year?
RE: Modding Plans For The New Year?
ORIGINAL: AdderMk2
something tells me that you havent researched your setup very well...
get 165's instead of the 185's... you can thank me later for the hp you will gain
ORIGINAL: 95 droptop
What are you modding plans for the new year?
AFR 185 Heads, E-cam, 1.6 roller rockers, trick flow intakes, UDP, A/C & Smog deletes, Long tube headers, O/R X-pipe, 4.10 gears, C&L setup, 70mm throttle body, 150 shot, MSD Dizzy, 6AL box, 130amp alternator, shift kit, SCT chip, and start workin on suspension. this is all i can think of right now. now i remember. 24lb injectors,FPR,255 fuel pump.
AFR 165cc Heads
Steeda #19 Cam
MM LCAs
New Clutch (undecided on which)
'03 Cobra front control arms
Hopefully new exhaust, hood, and wheels
KB if i find one i like [sm=gears.gif]
Steeda #19 Cam
MM LCAs
maybe you could tell me why. i was told to go with the 185??? could you tell me what sized of roller rockers i would need or will the 1.6 be ok?
ORIGINAL: AdderMk2
yea my plan is simple 12's and n/a
heres what i think the answer will be
1) afr 165
2) explorer intake
3) 24-30 lb injectors
4)throttle body
so far that will leave me with no money
1) afr 165
2) explorer intake
4)throttle body
