Fog Lights
Ever since ive had the car my fog lights have not been working...ive checked every fuse in the box under the hood and the under the steering wheel...when i flip the switch the little light even comes on so i know its gettin some kind of power...i dont really think both the bulbs would be out but its still a possability...any suggestions on other things to check?
well i have no clue how to get to them and i have no access to a jack so i can get under the car and look untill i drive home from college next...anyone know an easy way to go to the bulbs
the bulbs just twist out from the back of the houseing, you can to it with out looking under there as long as you can get an arm under it.... y can't you get under your car? and try using your spare tire jack just don't raise it very high it your gunna be inder it
yea me too, but the silver stars i had burnt out after like a month so i called the company and complained and they said that the bulbs are only designed to last for 24 hours of use.. but if i send them in the would replace them.... so i donno it they just said that to keep me from getting pissed or if it was the truth
if your bulbs are ok, check whether or not power is going to the fuse. if the switch is working correctly, but no power getting to the fuse, your turn signal switch is bad. the high beam circuit turns the fog's off, but could be stuck in that position.
