anderson cam
anderson cam
anyone know the specs on an anderson b-31 cam.
any hp estimates for a 306 with b-31 cam, 1.6s, twisted wedges, 24# injectors, ported upper and lower edelbrock performer intake(old style with 5.0 stamp), 70mm tb, 80mm maf, shorties and 5 speed? approx 9.5:1.
RE: anderson cam
Cam manufacturer Duration lift Adv. Dur. LSA ICL
Anderson AFM
AFM B1 220/222 .490/.530 110
AFM B2 218/224 .524/.544 w/1.6 rocker 112
AFM B3 218/226 .542/.542 w/ 1.6 rocker
AFM B4 224/232 .542/.563 112
AFM B25 218/226 .544/.544 w/1.7 rocker 272/280 112
AFM B-21 218/226 .542/.542 w/1.7 rocker 272/280 112 108
AFM B-31 218/228 .544/.544 w/1.6 rocker 270/280 112 108
AFM B-41 228/236 .544/.544 w/1.6 rocker
AFM B-4R(renegade cam) 226/234 .544/.544w/1.6 294/302
AFM B451 232/240 .576/.576 w/1.6 rocker 112
AFM N2 ? ? ? ? ?
AFM N3 218/226 .542/.542 w/1.6rocker 280/288 110
AFM N4 222/230 .512/.512
AFM N6 ? ? ? ? ?
AFM N-21 219/229 .512/.512 w/1.6 rocker 110
AFM N-41 222/232 .512/.512 w/1.6 rocker 110 106
AFM N-51P 228/238 .499/.4976 w/ 1.6 rocker 110
AFM N-61 228/236 .544/.568 w/1.6 rocker 110
AFM N-71 232/240 .576/.576 110
AFM N-81 236/244 .568/.576 110
AFM N-91 240/248 .576/.576 110 106
AFM N111 248/258 .576 ? ? ?
Anderson AFM
AFM N2 ? ? ? ? ?
AFM N6 ? ? ? ? ?
RE: anderson cam
heads,cam, intake,and exhaust are the best way to pick up hp with a 5.0
the exhaust ports on the stock e7 heads are the biggest restriction..if you are looking to pick up the most hp for your buck i would do a set of heads and an intake first with a set of shorty headers (the amount of hp between long tubes and short tubes on a stock motor is not worth the hassle) also an adj fuel pressure regulator is a good idea with the upgrades
junior04
09-28-2015 10:53 AM
