How long will my tranny last?
Trick flow street kit (h/c/i), 2.5" exhausts and headers, 70MM TB and egr, adjustable fuel pressure regulator.
Factory automatic transmission.....how long would you suspect it will last putting the higher amount of horse power to it? Car has 70K easy original miles on it.
RE: How long will my tranny last?
+1 Depends on how you drive the thing... if you beat the hell out of it good luck and you better start saving... if you take care of it and dont romp on it all the time it might last a week or two jp... it should last a while. Do you plan on doing any tranny work? vb, etc?
I was referring to gears in the tranny. AOD's are dogs off the line w/ stock gears (actually dogs all around), I just put 3.90's in my 93 AOD and its like a totally different car.
Cool....well this will be totally different car to me anyway because I only drove it around the block a couple times before I started tearing it apart. lol
ORIGINAL: 88BlueGT
