were you massively leaking anything? because with my general understand of motors, if there is still some coolant in the motor it wont over heat as fast as NO coolant at all. but normally if your leaking anything bad enough, you should check what it is before you drive the car
no i wasn't massivly leaking anything, i just checked teh radiatior itself and it is still full up to the top... so i couldn't have overheated it...
at least not to my knowledge
its actually in the front, like in between where the heads mount. itll have a little pulley like 2-3 inches indiameter coming out of it, inline with the belt.
No, the placer where its leaking is on the radiator like right under where the plug is to drain it... everything else is fine... i'm really concerned, cause i was expecting to get 1500 out of this car... and now i'm royally screwed.
