Can You Say Opportunity!
My dad's 00 Mountaineer has a crank knock so we pulled the motor out and decided to buy a diff motor motor with less miles to put in it. (the parts to fix it would cost 300$ and a motor with 83000 miles is 500$ out of a wrecked 00 explorer)Guess what i'm gettin off the old one.. can you say upper and lower intake and heads!
RE: Can You Say Opportunity!
the block needs to be honed because the piston that caused the crank knock also scorred the wall.. the rings were stuck inside the piston and the piston was loose inside the cylinder wall. it was a mess.
ORIGINAL: 89stanglx
You can use the throttle body also with a little modification, i saw it somewhere a few weeks ago.
