Bad MAF Sensor???
Old Dec 17, 2006 | 10:28 PM
mnile9127's Avatar
mnile9127
Default Bad MAF Sensor???
What makes a mass air sensor go bad?
The reason I ask is; I recently started having Idle and Driveability
problems with my car. Surging at idle and bucking while driving.
I changed my MAF/S(24lb calibrated) to the stock MAF/S, the
idle and driveability problem is solved but it created another running rich
at idle. I will be using my Tweecer to try and correct this.
Old Dec 18, 2006 | 01:11 AM
MACDRIVE's Avatar
MACDRIVE
Default RE: Bad MAF Sensor???
Low MAP sensor output voltage or a coolant sensor that reads cold all the time will allow more spark advance than normal. This, in turn, may cause detonation (spark knock) problems when the engine is under load. So too can a faulty knock sensor or an EGR valve that isn�t working.
High MAP output voltage or a misadjusted throttle position sensor can have the opposite effect and cause the spark control system to retard timing more than normal. Retarded timing will reduce performance and fuel economy.
Old Dec 18, 2006 | 01:48 AM
mnile9127's Avatar
mnile9127
So, the TPS may be the culprit. I'll Check it out 2morrow. THANX
Old Dec 18, 2006 | 01:51 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
have u cleaned the maf spray it with brake cleaner and wipe with a q-tip softly so u dont break the wires
Old Dec 18, 2006 | 02:09 AM
mnile9127's Avatar
mnile9127
Thats the first thing I did before I swapped them. I used Contact Cleaner w/ a cloth.
Old Dec 18, 2006 | 04:33 PM
vristang's Avatar
vristang
ORIGINAL: mnile9127
So the car was running well, then the idle went to crap, without any parts changes?
Can you datalog with the tweecer?
What adjustments have you made so far?
Puting a stock maf on while still running 24lb injectors will cause a rich condition.
We need to know more about the tweeks you have made.
What brand MAF was cal'd for the 24's?
jason
Old Dec 18, 2006 | 05:42 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
tap the maf's electronics with your finger to see if idle changes
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
