Nitrous+polymer intake+rev limiter=bad
This is what happens when you miss a gear and hit the rev limiter with a Comp polymer intake.
I run a wide open throttle switch but it doesnt work if you miss a gear and stomp it. I would recommend any 5 speed driver to install a window switch to cut the system off at an rpm before the rev limiter.
[IMG]local://upfiles/29088/92F6612C94794A38B1A039B7AB48F716.gif[/IMG]
[IMG]local://upfiles/29088/62C5A45148514E388D99D1936690B7C9.gif[/IMG]
RE: Nitrous+polymer intake+rev limiter=bad
that sucks
ORIGINAL: mcfomco
I edited the original post to mention the window switch recommendation to all 5 speed driver with nitrous.
ORIGINAL: 94gtcoupe
ouch, thats y they make window switches... and i think i'll stay with my aluminum intakes
Seem to be ok done compression test on all cylinders and turned out good. Also to answer the other guys question on the shot. It was a 150 shot that done it. It scared the **** out of me and the guy I was racing. LOL
ORIGINAL: motorman524
that stinks man. how are the internals, anything messed up ?
well at least u got out of there alrite and with little damage so all u need is an upper now rite
ORIGINAL: mcfomco
that would prolly scare the **** outa me too.. i bet that was a hell of a bang
ORIGINAL: mcfomco
