easy way to remove weight
RE: easy way to remove weight
Remove anything that isn't required. Door panels, carpet, engine accessories, emission equipment, get rid of tail pipes, fiber glass body parts, lexan or speed glass windows. A tubular k member with tubular arms and coil overs is about 80 pounds off the front end.
ORIGINAL: ZachW04Stang
ORIGINAL: primetime5.0
I have removed, all smog,AC,backseat,spare tire, front fog lights and supports,washer fluid container,sway bar,and the factory cats
ORIGINAL: Edge_of_Sanity
Isnt that a little extreme?? Thats not going to make that much of a weight difference anyway.
P.S. BTW Edge_of_Sanity we already have someone with an avatar that is pointing guns at people so you need to change yours
I was saying the part about removing door panels and carpet being extreme. the K member is a good move.
About the avatar, well mine is the zombie from dayofthedead, so it's different.You can change yours if you want but don't tell me what to do please.. It's not like theres more than 1 person with a Mustang on their avatar.
