battery
Old Dec 21, 2006 | 10:34 PM
howifeel2's Avatar
howifeel2
Default battery
ok the other day i was driving and i noticed my volts were low so i went back home the nexted day i went and had my alternator tested it took the dumbass like 45 mins to test it and then he said it was good..so i went back home and me and my dad were trying to figure it out so we took his battery out of his truck and hooked it up and his battery started to die so i went and got a new battery..i hooked it up and started my car and the volts started dropping so today we went and got a new alternator hooked it up volts still low and there at 8 so now we dont know what it could be...has anyone else had a problem like this?
Old Dec 21, 2006 | 11:04 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: battery
You need to check the power feed for the alt. What kinda car?
Old Dec 22, 2006 | 06:12 PM
5.0GTConveritbleGuy's Avatar
5.0GTConveritbleGuy
Default RE: battery
HEy im having that SAME problem any help woruld be great.
Old Dec 22, 2006 | 06:13 PM
7upedition's Avatar
7upedition
Default RE: battery
voltage regulator? or grounding issue perhaps....[&:]
Old Dec 22, 2006 | 10:37 PM
vt89gtvert's Avatar
vt89gtvert
Default RE: battery
What is with everyone and having electrical problems recently. First I would test things to see how much power you are losing and when you are losing it. There have been a couple of recent threads where I have gone over how I was able to find my problem (Just recently had similar problem). I would try to answere the following questions:
Is the alt charging the battery (Test voltage before and after start-up)
When the battery is charged and not hooked to anything will it keep voltage
Does the battery lose charge when it is hooked up and not runnning
Old Dec 23, 2006 | 03:42 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: battery
check the plug definitely goin in to the alt thats a common place for fires to start[&:] makes sure its not corroded burnt/melted etc
Old Dec 23, 2006 | 03:56 AM
Li0nHart's Avatar
Li0nHart
Default RE: battery
Might be related...My jeep Cherokee had a similar problem just last week. I would be driving and my volt meeter would be reading ike 8-9 volts. Turned out that my belt was slipping but not squealing. I tightened the belt and the problem dissapered.
Also make sure your engine block is grounded to the body with one of those braided stainless straps.
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
