24lb injectors
24lb injectors
I was wondering what is the max horsepower for 24lb injectors to the crank? I figure will the afr 165s and a tune i should be making around 350 at the crank and i was wondering if 24lbs would flow enough.
RE: 24lb injectors
n/a right? i'd say you'll be fine, i know the rails will handle well beyond that. But I suggest if you plan on power adder in future upgrade the FI while your torn down and adjust duty cycle accordingly for now, then in future retune with poweradder.
