Tremec TKO 600 vs
Tremec TKO 600 vs
Both have a 600 ft/lbs limit on torque, but which is better?
http://tremec.mrt-direct.com/ford500.php
http://store.summitracing.com/partde...p;autoview=sku
RE: Tremec TKO 600 vs
didn't know tremec made a trans tosell through for that is aftermarket. I think its the same trans as the TKO 600 but with a different name. It seems odd though because the trans they used in the cobra R in 95 was a beefed up t-5. It was only made to handle 325 ft/lbs tq. not 600.
Have you looked at a G-force T5? You don't have to buy a different shifter or bellhousing. Also,Astro Performance sells them shipped for $2k including a centerforce (IIRC) 28-spline clutch. Better deal if you ask me since you don't have to re-buy a bunch of stuff.
