torque box ?
torque box ?
has any one got a website with pics on how to install the upper and lower torque box reinforcements the uppers look pretty simple but they have a few pieces that im confused but lowers im lost on.
RE: torque box ?
sweet thanks bro i was told to bolt them in that it holds better than welding and the kit i got came with hard ware to bolt them in with but i think im gonna weld them in after i bolt them in.... it cant hurt.....
RE: torque box ?
i installed the torque box reinforcement kit, then welded all the seems under the car, then i tied the plates that go inside from the torque box kit into my roll cage. my torque boxes should hold
RE: torque box ?
yeah the ford technical ref manual says welding the seams is adequate. i guess the factory just tacks them in there. i'm not gonna buy the kits, just weld the seams. that should be ok since i have factory hp.
RE: torque box ?
you can fix the stock welds and complete them it helps a fair bit, but once you have sticky enough tires or enough power, reinforce them, you dont need a kit.. i just bought some steel and cut it to fit and welded it in.
