Code Problem
Old Dec 25, 2006 | 03:31 AM
mustnglvr's Avatar
mustnglvr
Default Code Problem
I hook up the scan tool but the computer wont put out codes not even a pass code and the scanner is fine. Any specific reasons whythe computer wouldnt put out any codes?
Old Dec 25, 2006 | 03:32 AM
mattdel's Avatar
mattdel
Default RE: Code Problem
fudged wiring or bad computer
Old Dec 25, 2006 | 03:36 AM
mustnglvr's Avatar
mustnglvr
I dont know shat about mustang computers any ideas where to start diagnosing the computer.
Old Dec 25, 2006 | 03:39 AM
mattdel's Avatar
mattdel
well see, there inlyes the problem. its impossible to positively identify a bad computer. only thing to do is rule out everything else, then replace computer.
Old Dec 25, 2006 | 03:46 AM
mustnglvr's Avatar
mustnglvr
Can a good scanner like a snap-on for the obd-1 system tell me where my problem is or are the obd-1 systems not that specific?
Old Dec 25, 2006 | 03:57 AM
mattdel's Avatar
mattdel
well, the problem your having is communication. if the computer won't go into self test mode, that means its locked in another test mode from long ago, or it could have created its own test and locked itself in it. i've seen it numerous times on older chryslers. snapon scanner will most likely produce the same results, although i believe it's also capable of re-setting the mode.
Old Dec 25, 2006 | 04:02 AM
mustnglvr's Avatar
mustnglvr
Thanks for helpin If I get it figured out Ill let you know. It will probably be awhile though.
Jb145700
Aug 21, 2022 06:37 AM
Golfsito
Oct 6, 2015 11:02 AM
TfcCDR
Sep 14, 2015 12:08 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
