87 fox and crownvic
RE: 87 fox and crownvic
Absolutely. The 8.8 is used all over Ford's lineup and should be in that CV. Don't use the carrier, as itmay bean open diff. I am not 100% sure if all police units got the trac lock. It's easy enough to tell when you get the cover off. Of course, there is the whole thing about gear mesh and wear patterns that may create issues after the install, but for a set of cheap/free gears, it is worth a shot.
thanks. Half of the things you were talking about was greek to me like gear mesh. I,ve never installed gears before but my friend said to buy instalation kit. Do you think the problems you was talking about is possible after install kit.
ORIGINAL: 3stangs
did you get the tag off of the crown vic rear diff cover, it'll tell ya if it had the trak loc... should of. but yes a few specialty tools are needed, bearing press/puller, backlash guage, torque wrenches, calipers, etc. plus your basic wrenched, sockets, drain pans, cleaner and stuff...good luck hope it works out well
01-21-2016 01:30 PM
