Need Technical Help
Old Dec 26, 2006 | 11:41 PM
jthorpe7525's Avatar
jthorpe7525
Default Need Technical Help
While my mustang is running there is a clicking coming from the engine. When I rev it up the ticking increases? Any ideas of what to check or what it could be?
Old Dec 26, 2006 | 11:42 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: Need Technical Help
loose rocker, collapsed lifter, or maybe even a exhaust leak
Old Dec 26, 2006 | 11:52 PM
92hatchLX's Avatar
92hatchLX
The lifters will make noise also if the car hasn't been started for a while. What type of oil are you using in it? When's the last time that it was ran?
Old Dec 26, 2006 | 11:53 PM
92hatchLX's Avatar
92hatchLX
Also, if you have got roller rockers they'll make a slight ticking noise.
Old Dec 26, 2006 | 11:54 PM
jthorpe7525
it has ran and nit sat. I am running penzoil with a lucas back.
Old Dec 27, 2006 | 12:00 AM
iceman89gt's Avatar
iceman89gt
ive got a ticking right now and after much investigation into the rockers i found one with slack in the rocker body itself not that it was loose stud and i replaced and fixed it. if a lifter is collapsed,and i know alot of guys are gonna say im nuts about this, but you can put some transmission fluid in the oil for and run it for a fix until you can replace them
Old Dec 27, 2006 | 12:16 AM
Li0nHart's Avatar
Li0nHart
ORIGINAL: jthorpe7525
I don't know about that Lucas stuff...i personally won't run it...
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Dec 27, 2006 | 12:28 AM
ddeaton66's Avatar
ddeaton66
Impressive photos
dba Brakes
Aug 21, 2015 07:07 PM
ccwebb
Aug 11, 2015 06:47 PM
