gas tank emergency!!!
im dropping my gas tank tomarrow and i was wondering if you need to unbolt the 4 bolts near the neck of the tank......right where you add the gas, it doesnt look like it will slide out.....another thing....i need to fix my baffle. i was wondering if JB weld could be used or if it would hurt the engine or something else.
i really need information please
thanks
thanks
RE: gas tank emergency!!!
you do not need to unbolt the filler neck, the tank will slide off it towards the drivers side of the car. simply unbolt the straps.
As far as the baffle goes... When the baffle breaks loose. Its time for a new tank. you CANT fix it
yeah i got the one on the strap....this sucks i dont really have the money to replace it....any recomendations on where to get them cheap....u thinka junkyard?? would that be reliable?
well im not completly sure till i drop the tank.....some times the car sputters and it backfired really bad n shot flames out the exhaust.....i asked around and they said that the baffle was loose and getting in the way of the fuel pump
