u/d pullies
Old Dec 27, 2006 | 07:21 PM
scooterstang's Avatar
scooterstang
Default u/d pullies
can someone please just walk me through the steps on installing underdrive pulleys? i know this sounds stupid but my dad doesn't beleive me that i can just do them in the driveway with an impact wrench. Thanks
Old Dec 27, 2006 | 07:32 PM
mattdel's Avatar
mattdel
Default RE: u/d pullies
you dont need an impact. just some sockets and wrenches should do the trick. all you gotta do is take the belt off, take the pullies off that you are changing, install new pullies, install belt. should take an hour, tops. you might wanna try and crack the bolts/nuts loose before you take the belt off, might make it a bit easier
Old Dec 27, 2006 | 07:43 PM
PJB's Avatar
PJB
Youre definately going to need an impact gun to get the alternator pulley off.
For the water pump pulley you need to unbolt the fan and then the bolts on the pulley. I removed the radiator brackets to make a little more room for the fan to come out.
For the crank pulley just undo the 4 bolts and tap the pulley off to remove it. The harmonic balancer doesnt need to come off.
I used the stock belt.
Old Dec 27, 2006 | 08:24 PM
89stanglx's Avatar
89stanglx
You might want to keep the stock alternator pulley on because of a lower output at idle, and by changing the crank pulley all accesories will already be using less power by slowing them down, but i dont know your situation or what you have. Def break all bolts loose before removing the belt. You still may have charging issues while idleing running electric accessories but give it a try and good luck.
Old Dec 27, 2006 | 08:42 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 89stanglx
+1 do not install the alternator pulley
Old Dec 28, 2006 | 03:42 AM
95gtdrop's Avatar
95gtdrop
i heard alot of bad thing about puting the alt pulley on. so DONT do it
ctgreddy
Sep 20, 2015 08:35 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
96mustanggt46
Jan 12, 2004 02:52 AM
VicsGT
Nov 25, 2003 07:07 PM
jBrandtGT
26
Sep 26, 2003 11:36 PM
